LG G Flex 2 pdf problems
Pottergreek
Hello, this is my first post. I have recently purchased a LG GFlex 2 and then activated it over T-Mobile. Recently i started having difficulty downloading PDF files from chrome. Any suggestions would be greatly appreciated.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Welcome to Android Central! What kind of difficulty? Is it not letting you download the PDF, or are you having problems opening it after the download? Do you have difficulties on any site, or just one particular one?
H3aTeRzz
2,810
Hi, Welcome to AC Forums!!
Try this: Settings>Device>Application Manager>FIND CHROME....
Clear Data & Clear Cache
If this doesn't resolve, try uninstalling Chrome, if possible then reinstall. If you cannot uninstall it completely, you "should" be able to uninstall last update.
Hope this helps!
Chris
