I got my battery tuned in from using about 60% down to 42%. But now it says Android OS is using 42% also But up from about around 20%. What would cause that? Is it normal?
There's been a crop of problems recently with Android System and Android OS causing excessive battery drain, especially over in Ask A Question. I take it you've tried the simplest thing, a soft reset? Has worked for me on two occasions in the past.
How do you do a soft reset on the G3?
Sent from my Nexus 7 using Tapatalk
