Obviously something is misbehaving and needs correction... It could be a recent app install?
If you haven't already, shut the phone off, leave it off for a minute, then power it back up. See if that resolves it.
Not sure. The only new app I have is chomp sms
I don't think chomp SMS would be the cause, your android system sits at 19% whilst mine stays between 8-9%. I'm not to sure what could be the root cause.
But the AC Guru's will arrive and offer more substantial input I'm sure
That would be unfortunate if it was the problem lol I like chompsms
Would you recommend letting it die and then doing that or no?
There's an app called auto data which turns off the data 15min after screen is turned off then turns it on every 20 min for 1 min. When the screen is on it will turn data on.I'm in a poor signal area (my building at work) so I'm forced to turn off data completely or else by 3:30 pm when I leave, the phone is nearly dead.
OP: I agree with the Power Off and Restart mentioned by others here, as a first resort. I've had this problem myself as I suppose we all have. In my case I charge to full in the evening and unplug. The drains always occur for me overnight. Perhaps you leave your charger plugged in overnight?...in which case the drain for you would occur during the day.
Yes I plug it in before I go to sleep. Never knew that was a bad thing. Because when I wake up, it's at 100% lol
