When I have enabled the application does not work properly. I know if I am missing a setting that needs to be turned on or what. Ever since I bought my LG g4 in October it has not worked. Any help would be great.
Can you get night mode to work? I've tried a couple of times but can't figure out how to disable the led notification at nightIt is now working, I cleared the data.
Since it is working to my liking I am not going to play with it anymore.Can you get night mode to work? I've tried a couple of times but can't figure out how to disable the led notification at night
