When you copy and paste the framework-res.apk over to system/framework you run the risk of the phone not rebooting but instead freezing where it should reboot. The only option youll have is to pull the battery. When you do youll be stuck in lg logo boot loop. ADB will not recognize the device to copy back the framework-res.apk either. I even tried using LGNPST to reflash my tot file but the device would only show as in standby mode. I used root explorer to copy the file over originally. It worked flawlessly and the freeze happened at random. So be careful and be aware that it can happen. There may be a method to get back into the phone. I did not try any of the boot loop methods I found but they may or may not work. I ended up getting a replacement.
The themes are safe in and of themselves. Its that the copying process doesnt seem to complete properly and the phone freezes during this. Its a random occurrence. So be aware there is a risk when using these themes.
