Moshe Barash
My Net10 LG L34C running Android 4.4 did in fact root with the string mentioned in this thread. Actually it failed once, but after a reboot I tried again, and it work and stuck.
I got it for free on a Kroger deal, and have no intention of using the cell radio. Wifi will do, so unlocking is not an issue.
What I would like to do is get a more up to date OS on it. Is there anything available, and does the fact that it is rooted help?
You would have to search for your device on XDA developers, if there is a dedicated forum for it then there are probably custom ROM's for it. And yes, being rooted helps.
