[Rom][WIP][ZVD] Slimmed CM10 Alpha 6
Status
Not open for further replies.
Re: [Rom][PORT][ZVD] jelly sandwich CM10 Alpha 5
I saw a candy cane, and half of Cid's face 0-0...
I would love to try this ROM, but I have a few questions.
1. Is the deep sleep issue still there?
2. In the settings menu, did CM include the 'CM settings' sub menu in there?
Cm9 and above has attempted to integrate its mod settings into existing settings. So the options are there, just not within a specific cm settings menu
Sent from my Nexus S 4G using Tapatalk 2
I'm happy :D
I'm getting a nexus s very soon 30 dollars to go and birthday is in November :D
As a result I know I will need to step it up and learn coding
So if I do this rom will be better all around.
Anyone wanna tell me the activity of rom developing for the nexus s sprint
Sent from my LG-LS670 using Tapatalk 2
Also I might be using bobzhome rom if zakman quits developing as he has said he might
I asked bobz permission he's a nice guy let's see what he says
I'm happy :D
The NS4G is outstanding on ROMs. Being in the nexus line, it has wonderfull devs to work it. Our own jstntp has a source built jb ROM that is quite excellent. Over on xda there are many many ICS and jb ROMs too
Also I'm going to wait till next release as bobz build has a data problem so very very soon
OK I will do it as it will have fixed camera but I want to crack at mms so expect it later
What are your thoughts on the mms fix? I would be happy to help out, if I had to direction to go. I have attempted to modified the following files without any luck:
cdmadispatcher.smali,
apns-config.XML
Build.prop
Sent from my LG-LS670 using Android Central Forums
apns-config.XML
Build.prop
I think I have to also replace mms .apk with the one in drews rom but yes your right
Replace apn.config with quattrimus cm9
Cdmas.smali I'm lost on how to edit it
So in order to flash this rom, I have to make a partition ext4 of about .5GB to 1GB? Last time I had to do that it kept erasing the data. Used easeus 9.1 home edition. Still in the kraven's cm9. MMS still works and camera. I know you're close to fixing the camera so I'll give it a try. Keep up the good work!! :):)
At least 1gb if ur. Game junkie
Use partition wizard home edition it works great
But you NEED a partition either way
MMS.APK shouldn't matter what so ever. In all the ports I do, I use the MMS from the from I'm porting.
Here is a modified eri.xml for Sprint which will override and replace the Roaming Indicator Off with Sprint. Using a root explorer, copy to the data directory and set the permissions as rw-r--r--., then reboot.
In order to incorporate this into this ROM we will need to replace the eri.xml file which is contained within the framework-res.apk.
https://dl.dropbox.com/u/11009817/eri.xml
Reactions: iantrich
I had to change mms apk to get mms send working in my zvj based rom on VM And build prop edits. Maybe if I find time I can take a look at helping get mms going here. I won't be able to test though since I don't have sprint service
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
Reactions: jonny5449
Click to view quoted image
Will include in next build thank u
Anyone care for the data problem in bobz cm10 cuz if not I will start working on the rom
Status
Techview
