Why close it? If you want to try and learn keep it up! Best is learning by doing.
Sent from my Nexus S 4G using Tapatalk 2
I don't know unless I learned coding
Which I can't my cp is a 90 gigibyte net book......
I have not made my mind anyone have or seen a good source building guide
Sent from my LG-LS670 using Tapatalk 2
Yeah, key switch yeah..nom non, also what about VM tag. Can I change that with file mgr? If so where?
I will end up making a key switch for bobz rom
But sellers says my ports are annoying so my next rom hopefully is from source maybe iho or cm10
I will keep links up for people
ty for fixing camera. ill try to install this tonight
To flash:
Unzip, edit the updater script in meta-inf/com/Google/android remove the whole first line regarding asserts (to the first semicolon).
As far as the virgin branding you would have to edit eri.XML in framework-res.apk I believe so its not an easy fix.
