Lg Optimus V won't boot into recovery and not sure if it is still rooted plz help
a.j.drop_dibz
I recently rooted my phone then I somehow unrooted it but it was still using a custom rom I deleted the gapps and ther file for cyanogens mod 9 after cwm started messing up and I couldn't find the restore and back up I saved I'm a noob pls help me fix
a.j.drop_dibz
Hope this helps you help me
Says my model is lg-ls 670
Android version: 4.0.4
Base and version: unknown
Kernal version: 2.6.35.7-HK-ICS-Cal-test15+thekraven@icsbox#16
CPU ARMv6-compatible processor rev 5 (v6l)
Memory 431 MB
Cyanogen mod version: 9.0.0-RCO-Thunder C kraven
---------- Post Merged at 12:14 PM ---------- Previous Post was at 12:09 PM ----------
The Power button + Volume up + home keys takes me to a black screen same as reboot to recoveryopt. I would love to reset to stock or any rom that will allow me to use all my features
A-android-B
414
21
This is most likely going to involve a PC and USB cable probably some adb and maybe some other things as well. I would lurk in the stickies in the optimus v roms rooting and hacks for the best assistance.
upconvert
486
3
Normally you boot to recovery by pressing down, home and power for 5 sec. What recovery are you running? Don't worry, you can probably fix it. You need a custom recovery and rom built for the optimus v(ov as a lot of people here call it). There are loads to choose from. I agree with a-android-b, read the stickies in the optimus v rooting roms and hacks forum, and post your questions over there. It's full of helpful ov owners!
Sent from my GT-P7310 using Android Central Forums
