LGFlashTool keeps giving me a connection error after it loads 100%. So that doesn't work. I need an alternative if there's any out there. I'm so lost right now. Please help...
It sounds to me like you have the same issue I had. It's the same issue as the G4 had with the motherboard and RAM. So you can either follow one of those guides for trying to fix it, or you can try to get it repaired or warrantied out. If you go for the later and you need to back up, which is what I'm doing, I suggest trying putting you phone on the dash of your car outside face up for 10 minutes or so (keep an eye in it), it should eventually get to the carrier boot screen. If it takes longer than normal to make it past this part, restart the phone. It eventually loads up like normal. And make sure your phone stays hot. If it cools off too much, it will die again.
wouldn't this potentially wipe all my pictures and videos??
Yes. If stored on main memory. SD card data will still be there.
