Hi,
I've got a big problem with restoring my data (contacts ans sms) from backup files.
I decided to set factory settings to my smartphone and before doing that I created a backup copy of some crucial data on SD.
Next I wanted to recover these, but Huawei Backup application can't open it, saying: "creating or opening the files are impossible. Check your SD"
I tried other SD cards - the same. Tried doing backup copies on a card or inner memory - the same answer.
On my SD card there are backup files (.xml and .db); ie. contact.db
Is it possible to read them, convert anyhow to . csv or. vcf fotmat (then I would import them ).
This is crucial for me - a lot of contacts are missing.
Can you help me?
Can you help me?
