I'll try the calibration thingy. thank you
but, 15% overnight "without" any activity, fully slept, no wifi/data, blue tooth, screen off etc. is bad in my view.
update - and now it's 20-25% drop overnight without any activity in 8 hours!!
help!
Hey I face same issues. Battery drains faster while phone is not in use than when it is in use. And also same problem- shows wifi ON even though I keep it turned OFF when not using. I tried clearing cached memory but got stuck on the first step itself. When it shows exclamation mark and no command. I pressed Vol Up key and Power key but dint proceed further. Please help if you can. Thanks!
wow Thats a lot of usage.
From the graph its showing that you have Wifi on.
Also what are the two symbols on the left. One that looks like an antenna and the second one that is a circle that says 72.
Another thing is its showing that the phone is "AWAKE" for almost the entire day. Looks like there is an App running in the background keeping the phone awake and draining the battery overnight.
Doing little short busts of charging can't be good either.
Here is a graph of my Moto G 2 over the last day. Notice the difference in the blue "AWAKE" graph.
This was right before I plugged my phone in.
Hey i would like to know what troubleshooting you did to extend the battery life.. I'm facing the same problem.. My phone battery dies out so soon.First of all Thank u so much for all your awesome replies
Last night I did some troubleshooting measures which gave me a great output.
I just have wiped my cached memory in recovery mode which is suggested in Motorola site for this type of battery issues. I have installed GSam battery monitor to get the accurate stats of my battery. Hope these things have really helped me last night it was just a 5% power drain in my battery.
Here is my battery latest stats of last 6 idle hours. Battery just got drained 5% only. Before it was like a huge animal eating my battery like anything up to 70% in the same duration of 6 idle hours. Feeling better and hopeful
hi
i have found a simple solution buy a power bank battery/ power extender ( battery which you can charge phone with via mini usb) plug this into charger and then plug phone into power bank or battery extender
