In-Call Volume Too Low Not Going Up...
silverfang77
Lone Wolf
Nov 6, 2010
880
18
18
If you just upgraded to Gingerbread, you need to reboot, which will clear up the call volume problem.
Sent from my DROID2 using Tapatalk
Mark7thh
Unfortunately GB bricked my Droid X phone about a week after the OTA update. Before it killed the cellular radio I was also having issues with the volume always starting in the tank & having to turn it up. Well, Verizon had to replace my phone and it came pre-installed with GB and it has the same problem. Volume at its lowest level at the start of every call so this restarting issue won't do it... It's an actual issue with the GB update that has to be fixed.
delrey1900
751
I just had the volume issue today. A simple reboot fixed it but I'm sure I will encounter it again. Kind of missing my OGD.
cloudsofmana
