Phone is completely normal while using plug-in chargers. Discovered wireless chargers (Verizon VZW3COIL or TYLT). These were great at first, but at some point (seemed to be associated with using the phone in Bluetooth mode) battery indications would go crazy. Battery status would bounce from 100 % to random values (86%, 93%, 100%, 86% etc.). Once the phone rebooted itself while on the Qi charger. Taking phone off charger cause battery indication to drop rapidly. Turned phone off and the charge level counted down to 0 (zero) as it shut down. Phone would not boot, just got the dead battery indication. Took to Verizon store. They COULD BRING UP PHONE IN TEST MODE. Only way to get phone to boot was to put it back on charger (wireless or plug-in). Charge level would rapidly climb back to 100% (in minutes). Taking it off charger would cause it to rapidly loose charge and crash. Verizon gave me a new phone. Same thing happened to second phone. Went back to Verizon Store. Did a factory reset and have not used Qi chargers since. Phone is normal. Tech support was bewildered by this behavior.
HAS ANYONE SEEN THIS BEHAVIOR? The Qi chargers are great. There is a problem in the Turbo firmware associated with using Qi chargers.
