DroidDev Superstar Status Oct 5, 2010 684 177 0 Visit site Jan 18, 2011 #1 Any of you find that the market search, download, installation of apps is very slow after flashing Liberty?
T tntdroid Droiderator Feb 19, 2010 4,473 615 0 www.flickr.com Jan 18, 2011 #2 Nope. Just bad battery but fixed in recovery. Sent from my DROIDX using Tapatalk
DroidDev Superstar Status Oct 5, 2010 684 177 0 Visit site Jan 18, 2011 #3 How did you fix the bad battery?
K kentusmc Well-known member Apr 2, 2010 320 17 0 Visit site Jan 18, 2011 #4 In recovery got to advanced>reset battery data
K kentusmc Well-known member Apr 2, 2010 320 17 0 Visit site Jan 18, 2011 #5 as for your market issue, did you do a fresh install or did you install over another rom? I believe I have seen another post where someone had the same issue because they installed over GummyJar 2.5
DroidDev Superstar Status Oct 5, 2010 684 177 0 Visit site Jan 18, 2011 #6 Fresh install. I am reinstalling some of my apps. They are downloading VERY slow. 4 bars of 3G.
C ceriem Well-known member Jun 23, 2010 450 10 0 Visit site Jan 18, 2011 #7 Could Verizon possibly be throttling your data (i.e. you went over their invisible cap?)
