Creamed Glacier Rom boot loop Help PLz
kilo720
56
this is my first time rooting , and try flashing creamed glacier rom and now it stuck in the boot animation n and it keep looping what i do to get it to stop boot loop?
radamo
16
I have solved this with prior bad loads by doing a battery pull...after replacing the battery, press power and also hold volume down. It should put you into an engineering type boot screen. From there you can get to recovery.
RA
