So, this is how everything went. First I unpacked the device and plugged into my PC with a USB cable. Then I
1) Updated the driver for the "unknown device" to a "Samsung Android ADB Interface" driver that I downloaded for the Galaxy Nexus. It is dated 9/21/2011
2) Fastboot OEM Unlock
3) Confirmed Unlock
4) Restarted the device
It stayed on the Jellybean "X" logo for about 25 minutes before I decided it was likely borked. So this is what I've tried since (each time doing a hard reset into the bootloader after failing to boot past the X)
*Relocked the device and boot
*Relocked then unlocked the device and boot
*ADB pushed the factory image "image-mantaray-jop40c" using the instructions from the Nexus 7 forum and using the Nexus 10 files instead.
Nothing has worked so far, and I can't imagine what is causing the problem. Do I need a Nexus 10 specific driver for the ADB interface?
Any thoughts?
3) Confirmed Unlock
Any thoughts?
