Rooting Nexus 4 4.4.2 without wiping data?
fuzzylumpkin
5,555
2,558
113
If your bootloader is already unlocked you don't have to wipe anything, rooting doesn't wipe your data. Just install a custom recovery or use fastboot to root, a decent guide lies within the stickies.
PlusJack
50
If you're going from pure stock to unlocking the bootloader and rooting, I don't believe there is a reliable way to save everything. You MIGHT be able to do some workaround to back things up but I'm not positive.
Sai Mohan
5
Yes, you can. Since you already have an unlocked boot loader, all you have to do is flash a custom recovery such as twrp or clock work mod and then boot to custom recovery. Flash the zip file required for root and restart
Sent from my Nexus 4
smokedog87
