Anyone have or found any decent car mounts I don't want a windshield or vent mount one.
I just got the spigen one for Christmas and it is amazing!! I've had vent and suction cup ones but they all broke cause of heavy phones.. This thing is great!!!
I got this Aukey magnetic vent mount:
http://smile.amazon.com/Aukey-Reinforced-Cradle-less-Smartphone-HD-C5/dp/B00WU3W43G/ref=sr_1_5?ie=UTF8&qid=1452542267&sr=8-5&keywords=anker+car+mount
I use it with a Spigen thin fit. It's strong enough to hold my 6P in place but you do have to make sure when you mount your phone it is centered. If it's slightly off center, it will hold initially but a bump will knock it off.
I got this one last year, before I had the 6p but it works flawlessly for it too. What I like is that you can turn it to any angle you want and it's a tight fit, so doesn't wobble.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4953665
I'm using the Aukey mount that fits into the CD slot. Flipping the mount up let's it clear the display on my car. Sound and power switches work with no problem.Anyone have or found any decent car mounts I don't want a windshield or vent mount one.
Link isI'm using the Aukey mount that fits into the CD slot. Flipping the mount up let's it clear the display on my car. Sound and power switches work with no problem.
Anker CD Slot Mount Car Mount Phone Holder for iPhone, iPod, Samsung, LG, Nexus, HTC, Motorola, Sony and Other Smartphones and MP3 Players*
Ibolt makes some of the best mounts in the business. They also have a companion app called Dock n Drive on the Google Play Store. They recently came out with one that is compatible with USB-C.
iBOLT cPro Type C USB Car Dock with NFC | BlackBerry Car Mounts | ShopCrackBerry
