Story is that my sister has a LG optimus v (as do i) but hers was on stock whereas mine was rooted since January. She had some bugs (text messaging and calling just failing on open) so I told her I'd just root it and flash CM7 on it for her and it'd fix the problems and help with things like battery life. Here are the series of events that transpire.
>Problems arise. She calls tech support, they have her try to troubleshoot it through resetting the phone things to where MIN and MEID or whatever are changed to 1111111111. She does this, but doesn't set it back to the numbers. (I was unaware of this).
>I root and flash it just fine, but it still won't make calls and it will not send texts or receive calls. Just asks if I'd like to make a toll free call.
>Confused, I restored and tried unrooting through Gingerbreak by pressing the un-root button. Still doesn't work.
>I'm like wtf so I do some digging and find out that since it's trying to call from that number, it's obviously wrong. I then get a call to go pick up my brother from work, so I leave the phone with my sister and my dad to call VM and ask them what the numbers are so that they can be returned to normal and it would be functional again. I restored the phone back to the backup from before because I was convinced it was the root that went wrong and not the number, so that means it was booting into her previous thing. Bugs were gone - messaging and phone apps were not shutting down upon opening.
>They get the numbers, put them back in, phone still doesn't work. This is done while I'm gone. I get home and instead of just taking the phone, I let him continue on with the phone call. Of course, they tell him to do a factory reset. NOPE NOPE NOPE NOPE NOPE.
>They reset it.
>I try to restore it, goes into recovery reboot loop.
>After some serious googling, find this: http://androidforums.com/optimus-v-...tory-reset-your-rooted-phone.html#post3263770
>At this point I try downloading the .zip file and putting it on the SD card (Mind you, the computer will not read it through the phone despite trying to turn on USB sharing. I have to use a separate phone to get it on the SD card in the first place).
>Try go to install from .zip, just keep getting that the installation has failed. I tried putting the .img within the .zip, as well without. Neither work, same error. This is where I'm stuck.
What do I do? Currently I'm downloading the SDK for Android, hoping I can get the adb shell somehow so I can install it through the computer but my hopes are not high.
I feel terrible because I essentially bricked my sister's phone which she paid for herself.
>They reset it.
