[ROM][PRE-ALPHA][PREVIEW]CyanogenMod 10.1 for the Optimus V![4.2.1]
kenharkey7
222
18
Working:
It boots
Congratulations on getting that far, can't wait to see the progress.
sellers86
1,837
617
That's kind of rude. Don't you think that was just a little bit disrespectful? Yeah its great that other devs are working on it too but its not right for you to barge in and just say what's working in another build. It doesn't make this dev any happier.
Codename: One V.
I'm going to take it that he's just trying to help me out by telling me about the build. See my post in his thread, progress will be slow
Sent from my HTCEVOV4G using Android Central Forums
flapjack.fiasco
776
102
That's exactly what I was at. I'd rather see a native build than have to use a patch.
sellers86
1,837
617
Thanks for letting me know, though I'm going to take a different approach to it, might fix most of the issues
Feb 19, 2011
1,971
284
I've been too distracted to build, but if you want full gapps you could try this:
build aufs filesystem into kernel (from SourceForge)
use existing /system/app from your build for base read-only directory
have init.d script that aufs mounts a 2nd sd-ext partition over /system/app
copy gapps with adb or terminal after script runs and reboot
it's possible the os would be uppity on boot from not having access to some apps until the card mounts, but it might work since your base install is accessible.
nice job getting this to work, by the way!
sellers86
1,837
617
I'm going to get the issues kinked out before anything :)
inceyet
393
121
WORD!!! Your a beast sellers great job . Will DEF try out as soon aa I can just to see.
MWisBest
45
18
As soon as i get done with these funerals and get my keys set up.. Why?
Sent from my PG86100 using Android Central Forums
It'd be a nice project over break to try and get it going on my LG Vortex. I want to see what was done with the androidarmv6 sources to get it built and booted on the Optimus V as the hardware isn't too different between the V and Vortex.
sellers86
1,837
617
IIRC, all changes were in the device tree.
willmon22
109
3
Just seen this today. I am going to download it and try it out. Thanks for making a rom of the latest android sellers you are awesome.
willmon22
109
3
Thought I would review the rom and give my opinion on it. The rom itself is fine. I will compile a list as writing sentence after sentence takes too long.
1. Phone/3G Network
2. Wifi
3. Bluetooth
4. Camera
5. Sound
6. Vibration
7. Brightness adjust
8. Screen Rotation
9. Sound Recorder
10. Headphones
Things that do work
1. Font size adjust
2. Changing Wallpaper
3. Rom boots and fuctions
4. Lock Screen
5. Pattern lock screen
6. Gmail installs
Also there is the USB storage. When I first installed the rom it worked fine. But now it isn't. I had tried to install the newest gapps and it went through fine with no errors. Just I can't seem to find the google play market just gmail. I am going to be testing the rom further to see if I can find any other issues. Also if I find ways around certain issues I will post them. Other than that sellers I hope this info helps out. I can try to confirm more but I would have to find out how to install apks without there being a filemanager installed already.
thewraith420
1,987
223
63
Not knocking sellers work on this but you should check out kravens jb work in the Optimus S forums. It has more working since he's had more time working on it.
Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
RandyRoyalty
