HELP My phone won't boot up!!!
QuinnSF
122
My SD got ejected so I thought I'd reboot my phone instead of taking it out and putting it back in. Now my phone won't turn on. I am running MiRaGe and my phone won't go past the green android icon with the word "ANDROID" on the bottom. It'll show the LG icon and then the green android mascot icon but after that there's nothing but a black screen and lighted up buttons. I've tried booting with my phone plugged in and that does the same thing. If I pulled my battery and then put it back while plugged in, I'll get the charging icon. If I have it plugged in but no battery, it'll tell me to insert a battery. What do I do??? I've tried booting into recovery by pressing all the button at once and bu pressing the power button, home button, and down button but I have not been able to get anything so far.
AndyOpie150
1,254
32
Have you tried getting into your recovery by unplugging phone from any power, then pressing the keys in this order exactly:
HOME + VOLUME DOWN, then push the POWER. Hold everything until you see the LG logo, then let go of all buttons.
If this doesn't work we wil need to see if you can get into Emergency mode.
BACK + VOLUME DOWN, then plug into computer.
Let me know how it goes.
QuinnSF
122
I got into recovery mode and from there I rebooted my phone and it booted up as normal. Thank you!
aykahs
I am having the same problem. I have HTC One M8. My apps started crashing one after another. I could not open a single app. So I tried the factory reset option. But now the phone doesnt turn on. the screen gets stuck in the boot page with htc and beats audio. can you help me out as well? the whole problem started since I updated the Kitkat 4.4. pleaseeee helpp
Hazel Green1
i rooted my phone and i happened to accidentally uninstall an app and my phone wont open.. only the welcome screen appears and it stops there :( Please help me too. Is there a way to open my phone? Please help me Please!
Feb 19, 2011
1,971
284
if you're rooted, did you install a custom recovery? if so, the instructions should've told you to make a backup. you can restore that and be ok.
if you didn't install a custom recovery you can factory reset in the stock recovery (probably lose root but you can get it back.)
you are using an optimus v phone, correct?
Romey101
Please help me my phone wont boot either, it wont pass the Blu luanch screen...i have a Blu advance 4.0 android 4.2.2 jelybean.
sonu kumar12
my mobile colours teletalk X120Q is not starting. after press volume down + power it gives option of boot but on boot the phone is not starting up it only shows logo
sonu kumar12
Feb 19, 2011
1,971
284
I rooted my phone and it wont boot up i tried doing factory reset that did not work i am on samsung s5
sorry folks, optimus v forum, can't help with any of those devices here.
