Superorb
You get half a check added back thenlol well if it's any consolation, it's a long distance relationship and there's no guarantee it'll work out ;-)
One thing to note here.
I was running at 750/75 for a while, and while the battery life was great at idle, while streaming music or using GPS, the phone can get awfully hot. Even worse if you revert to a cheap Taiwanese battery.
I wouldn't recommend doing 200/750, but I have started using something like 400/750 and am having pretty good results. It's probably high enough to avoid the lag and ups and downs, but keeps it from running at full bore anytime some minor process is being run.
^^ You want it to be at full speed even for minor processes since it completes work faster at the higher speed while using less power than it would at a slower speed comparatively speaking.
Great, glad you like it!btw, allow me to thank you for the Aphrodite ROM, i'm using your 1.3.3/Xeonia05 ROM and it's solved almost all of the issues i was having with this phone... great ROM!!
2.0 is getting there.
mmarz, do you know anything about the program i am using, the no-frills cpu app? it seems to have very few options compared to SetCPU, only allowing you to adjust the min, max, and governor (of which my available choices are conservative, ondemand, performance, and interactive)
do you know if this app works in the same/similar fashion as SetCPU?
I know where you're coming from, LeslieAnn, but the problem with that logic is that it assumes SetCPU is smart enough to figure out that your CPU clock should be set to the lower speed when you are streaming. From what I've seen, this isn't the case. If there is any CPU load, SetCPU sets the speed to max. Even with the conservative governor, SetCPU will bring the clock speed to max, just at a slower pace...
mmarz: you seem to get pretty good battery life with 3G on all the time and moderate usage... would you think it would be more of a draw on the battery to have 3G on constantly, or to have the 3G radio constantly connecting/disconnecting every time i turn my screen on/off to answer a text?
superorb: thanks for the heads up!! i probably would've never found that on my own!
mmarz: i agree, lol -- could you recommend a simple, free app that would display my current CPU frequency so i could do some testing at different threshold values/governor settings? i've been searching the market for something, all i really need is an app that displays the current frequency
