[Guide][TOOL] How to root fastboot style. Fastest easiest way around
Status
Not open for further replies.
Re: [Guide][TOOL] How to root fastboot style. Fastest easiest way
Pull your battery then put it back in. hold down the volume down key plus home then press the power. Hold all of those down and see of you get to recovery. If you do then put a rom on your sdcard wrote all data system boot and cache. Then flash the zip.
I have tried that. I have cm7 on the card, but the installation fails. can you give me a link to a rom that you know will work?
Sounds to me like a user error. Can you tell me how your flashing these roms what roms are you using? Try the basic stock rom just to find out.
Status
Dsignluckmezc
