Results 1 to 1 of 1
    pancakeproxy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Firmware update failed. Phone stuck. Please help!
    Hi everyone,
    I bought an unlocked phone and it worked fine. However, when I connected it to Kies, it told me that I should upgrade it to ICS. So I did. But it froze halfway, and I decided to pull the USB cord on it thinking that I would be able to just not upgrade it and that it would be fine. All the phone says is that the Firmware upgrade failed and that I should connect it back to Kies to try and get it to recover. I tried it and the emergency recovery thing didn't work. The recovery mode doesn't work either. It just stops loading halfway through.
    I figured that I should try and completely re-install the phone, but Odin gets stuck on NAND write start.
    Since I bought it online and it's unlocked, I doubt I can go to a retailer and ask them to help. I'm completely stumped and I have no idea what to do now. I just bought this phone and I'm super frustrated already.
    Any advice? Please help!
    Thanks
  1. Replies: 20
    Last Post: 03-27-2012, 07:10 PM
  2. Phone broken please help!!!!!!!
    By Ryuk6666 in forum LG Optimus S
    Last Post: 03-15-2012, 10:35 PM
  3. Rooting with Mac and stuck, please Help!
    By jnl813 in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 09-11-2011, 11:06 AM
  4. post 2.2.1 update, cannot make calls. please help
    By lster in forum Sprint Epic 4G
    Last Post: 02-26-2011, 08:08 AM
  5. Rooted problem im stuck please help.
    By laraiza in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-07-2010, 12:40 AM
