How do I get notifications on my gear from go SMS?
Before I had the update, I tried a few things and really never got it working well. After I loaded the update a few weeks ago, it has worked like a charm. I did end up turning off the pop up option in Go because it was no longer needed.
Here are the instructions I had used before the update:
On Go SMS:
* Notification Settings:
- Enable Notifications: on
- Default Notif. Settings: disabled Vibrate.
* Other Settings:
- Disable other message notification: unchecked.
On Messages (Stock):
* More
- Notifications: checked.
- Vibrate: checked.
