Hello All
I am trying to use S note but am having some problems, can anyone please help.
I am unable to get to the settings to change the cover or delete a note. According to the manual you should tap on the cover icon and use the menu that appears. When I do this it opens the note and goes straight to the pages to allow editing. If I hold my finger on the cover icon it just allows me to reposition or remove the app.
Also all notes are in landscape format and only have a few templates, how do I change the format to portrait, just turning the screen does not do this.
Is it possible to reset the app to default mode and if so how, perhaps this would solve my problems.
Please help if possible, I am a 64 year old trying to get to grips with new technology.
Many thanks,
Phil
Many thanks,
Phil
