Hi Guys , please check my chat with SAMSUNG service in my region could that help some ....
You are connecting with LiveChat system. If it takes a few minute, Please Try again.
(Our web team will be with you soon.)
A member of our web team will be available soon. You are currently in position 1 Thank you for waiting. If your enquiry is concerning a purchased product, please have your product details, including serial number and date of purchase ready.
Welcome to Samsung Live Chat. How may I help you?
Hussein Qassim :
Hi
Hussein Qassim :
i have problem with my new Note 3
AE@#aeagent001 :
Good day sir. i had read your comment
Hussein Qassim :
its showing IndexService stopped , getting this message
Hussein Qassim :
every 1 minutes
Hussein Qassim :
ok good
AE@#aeagent001 :
so it appears every one minute in a pop up message
Hussein Qassim :
correct
Hussein Qassim :
yes
Hussein Qassim :
and freeze the phone
AE@#aeagent001 :
do you have dropbox account?
Hussein Qassim :
and come again
Hussein Qassim :
no
Hussein Qassim :
i don't
AE@#aeagent001 :
have you tried to restart the phone sir?
Hussein Qassim :
i did and i rest to default
Hussein Qassim :
but the issue still existing
Hussein Qassim :
from the second day i purchased the phone from DU
AE@#aeagent001 :
do you have any memory card on the device?
Hussein Qassim :
yes of course
Hussein Qassim :
16 G sundisk
AE@#aeagent001 :
can you test by removing the memory card and check if the error appears
Hussein Qassim :
ok ,
Hussein Qassim :
i will try that
Hussein Qassim :
and what if disappeared the error
Hussein Qassim :
its mean from the memory card ?? its brand new one
Hussein Qassim :
i read so much blogs on the net and many customer of Note 3 facing this crazy error !!!!
AE@#aeagent001 :
if it disappears.. try to copy its content to your pc and format the memory card first
Hussein Qassim :
ok , and then ??
AE@#aeagent001 :
its actually the first time i know this but we will be checking this issue.. nonetheless, if the problem persists even removing the memory card.. kindly report to us with screenshot of the error...
Hussein Qassim :
thats all !!! i bough costly phone and i can;t use it
Hussein Qassim :
to whom i report ??
Hussein Qassim :
give me email or contact number
AE@#aeagent001 :
sir, i apologize for this inconvenience... you can send report from the link below
AE@#aeagent001 :
Contact Us - Samsung
AE@#aeagent001 :
please do first the following
AE@#aeagent001 :
remove the memory card and copy the contents of your memory card to pc to make a back up..
AE@#aeagent001 :
return the memory card to the phone and format it there.. if possible, try to format again your memory card
AE@#aeagent001 :
i mean try to format again the phone
Hussein Qassim :
ok format twice from pc and mobile
AE@#aeagent001 :
yes sir.. but it must be formatted last in the phone
Hussein Qassim :
ok , got it
Hussein Qassim :
so you think the problem with the SD card ??
AE@#aeagent001 :
sir, may i know your location please
Hussein Qassim :
Dubai Airport Free Zone
AE@#aeagent001 :
index issue is with files being save on the device and phone
AE@#aeagent001 :
okay sir. noted with it
Hussein Qassim :
ok , i shall do what you instructed me and i hope this can fix the issue
Hussein Qassim :
bc i can't use the phone
AE@#aeagent001 :
just in case you still face problem, you can still contact us in Live Chat. non the less, you may call 800-7267864 to get more assistance or raise a complaint
AE@#aeagent001 :
i hope so sir..
Hussein Qassim :
ok , of course i will do
Hussein Qassim :
but i wish this can be sloved sooner as many of Note 3 facing same issue
AE@#aeagent001 :
800-7267864 is toll free number so please fell free to contact it
AE@#aeagent001 :
noted sir.. just in case it cant be solve, please send us emal also from the link i gave so that we can escalate to concerned team.
Hussein Qassim :
thanks very much i will do what you told me and hopefully it can be solved
Hussein Qassim :
thanks for your time and assistance
Hussein Qassim :
another things with this issue once its appear its killing the battery as well , just for your information
AE@#aeagent001 :
noted with it sir.. hence, please check first if problem is solved with regard to index..thus, if it is fixed, pls observe battery functionality
Hussein Qassim :
Thanks
Enlarge Reduce
Message input
