My note 3 powered down and then now won't charge or turn on even with new battery
Python49
8
I have tried to use the toothbrush method to clean the usb or charging port. Have tried rapidly making battery and charger tips touch method. Have tried blowing into there but it's clean considering the phone is only like one month old. I have used a new battery that is fully charged and it's not turning on or any red light when plugged in for charging. Have used new charger and wall outlet. Have held down the volume up/home/power buttons. Taken battery in and out numerous times. Any help?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Ugh, sounds like you've tried everything I would have suggested. The last time it powered down, did you do it yourself, or did it shut down by itself? It sounds like a major hardware failure--possibly the motherboard. I think you'll probably have to contact Samsung for repairs--hopefully it's still under warranty.
