Samsung Galaxy Note 4 Smart select settings?
amer369
23
I been using the note 4 for a month or 2 now. Getting to grips with the air command options.
I use action memo quite alot,image clip and screen write quite often too.
I see the benefit of smart select of having to take clippings from multiple sources and then either store or share them together.
The issue I'm having is I'd like to make multiple clippings and share them via WhatsApp or S note but I don't want the ocr function.
What seems to happen by default is that if I share the clippings with another app I get those clippings plus the text from those clippings sent together. The result is quite messy.
Is there a way of turning off the ocr function when sharing the clippings?
