How much galaxy note 4 battery should last without save power mode? While using Internet and Facebook wattsapp + phone calls??
In normal situationNo one here can tell you since how much you use those will affect how long the battery lasts. Screen brightness will also affect the battery.
In normal situation
That it is. On my Note 4/Note Edge, I get these usage times and this is still on the original batteries which are now 1.5 years old. The Note 4 is rooted, the Edge isn't.Which is fantastic when you think about it. That's 48-72 hours of runtime.
