Note 5 Tempered Glass Screen Protector, Same problem as Note 4?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
If you are referring to the halo effect then yes.
Sent from my Verizon Samsung Galaxy Note 5
zmann
3,306
120
No,, just had a Zagg put on,, NO halo at all. It's perfect, don't understand how anyone could just answer yes. Lol
Sent from my SM-N920P using Tapatalk
05GT
540
5
So far I've purchased two different tempered glass protectors and they work fine. The one Verizon sells is perfect when you get it perfectly centered. If you don't get it centered, you will have the halo (ask my wife). I also purchased two of the JETech tempered glass from Amazon just because they were cheap. They also work perfectly fine!
E Padilla
103
I'm using Zagg and it has the halo effect. Unsure if I should get it re-done after signing up with Zagg for their warranty.
sfla99
421
Does the BB Zagg use blue screen tech? This was an issue with the Zagg best buy sold for the s6, it would halo.
Best buy actually has their own version of the Zagg glass.
The ATT Zagg is flawless though.
E Padilla
103
Unsure it looks like normal. Here is a picture: EH0l1oc.jpg
Not really sure if I should get it re-done or if its pointless lol.
sfla99
421
I'll have to look at the box of the AT&T version but I am near certain that is the best buy specific one with blue screen thing, notice in the top corner the sticker about UV protection.
Sent from my SAMSUNG-SM-N920A using Tapatalk
E Padilla
103
I went back to BB and they were like that's a common issue for note line phones but I should wait 48 hours. They said if its still happening after 48 hours I can bring it back and they will apply another one without any issues.
verks
427
8
18
Wait 48? Lol they are just trying to get away from not replacing it. No halo is disappearing only some bubbles will vanish. With tempered glass if it's not on perfectly the first time it will never be.
smokedog87
