I am a fan of the double edge screen!
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
I heard a lot of people saying its not useful, but I find it pretty awesome!
I absolutely love Edge lighting, I think its a pretty cool feature
And I do love the edge panel mostly for sports scores and to check my stocks which I use
Anyone else find the edge screen useful?
jshah500
268
I have the edge screen feature set up, but don't see myself using it much. Probably just need to get used to the fact that it's there.
James Pettengill
Active member
Jun 9, 2013
28
I'm a fan of the edges. That was the whole reason I chose the S6edge+ last year over the note (always been a note user) I wanted the curved edges and something that was different. I wish they would have stuck with the same edge profile as the edge+ tho. These edges on the note are okay but basically useless as an edge display. Most everything is just on the edge of the screen. At least on the edge+ the actual edge was readable from well, the edge when looking at it from the side. But this is still a great blend of the two devices, note and edge+.
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
For a normal screen, it's fine. For edge purposes, especially the night edge clock, not so useful.
So, if you are really wanting a phone to take full advantage of the edge features, get the S7 Edge, not the Note7.
Thisistip
95
I love it but I'm a previous a note Edge users. I actually want more of an edge
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
What's the difference between the S7 Edge and Note 7 edge screen? I thought it was the same
