Yeah but it doesn't stay there. For example, if I receive a text and 5 mins later I check my phone, it won't be there... versus normally if I receive a text and check my phone, it'll be sitting on my screen for me to read.
I can understand what you're wanting to do, but with the Note Edge you may need to consider adjusting the way you have customarily done some things.
In order to do a simple check for notifications, with the screen completely off, with the Note Edge, you would do a quick back and forth swipe with your index finger along the panel and all your notifications will scroll along the panel without turning on the full display.
You can set the panel off time anywhere from 15 sec. to 10 mins. I believe.
