Hi
I have a Samsung Galaxy Note Edge and I upgraded to Android 5.0.1 using Odin a little while ago. I don't really like lollipop though atm. It seems to drain battery much faster and keeps randomly closing apps when I am using them. So I went back to Odin to reflash the old Android 4.4.4 firmware however when I tried that I got stuck in a boot loop. Firmware would install, successfully but then it would get to the Samsung logo and hang there for a while before rebooting and doing the same thing again. I tried 3 different versions of the 4.4.4 firmware (stock and branded) and tried re downloading the firmwares off Sammobile. Same result. I went back and reflashed the Android 5.0.1 firmware and that loaded fine again and all my settings were still fine. I can put up with Android lollipop if I have to but if I could go back to kitkat it would be better. Does anyone know why kitkat firmware keeps getting into a boot loop? Am I using the wrong version of Odin or something? I was using Odin 3.09.
Thanks
Thanks
