Essentially it opens up a quick note pad for you to take notes on and shows your current appointments along with a monthly calendar every time you open up a case that magnetically triggers a sensor in the tablet (located about an inch to the right of the Samsung logo on front and an inch down from the bezel).
hi - is there a way to change the thickness of S Pen while using Daynote. I know this can be adjusted in S Note but cannot figure out how to do this in Daynote if at all?
