Hi guys,
I purchased a Note Pro in pretty damn good condition on the outside, and perfect on the inside. (So no liquid damage).
The fault is that it's dead. I can't get any response out of the display, speakers, vibrator, notification LED, etc.
What I've done:
- Re-soldered battery connector and verified pin contacts.
- Every vol+power+home combo that exists.
- Re-seat all connectors and ribbon cables and verify lower LCD connector.
The only life it has is the chip that's under the can that's closest to the SD card gets warm (only when connected to charger (5V/2A)) and the battery voltage slowly increases when read by my multimeter. When I purchased the tablet I think the battery voltage was around 2.6v. I trickle charged it up to currently 3.75v. Still no life. 2.6v is very low for li-ion but I don't want to spend money on a battery if there's another fault. I have no bench supply.
One more thing I noticed. There's two blue wires coming from the battery. One of them measured between ground gave me some stable voltage, like 3.5mv or something like that. The other blue wire is all over the place. I can't get a reading from it, and I was measuring from the white connector so I know I was making contact. I'm not sure if this could be a fault stopping the tablet booting?
Is there any test points on the PCB I can check to diagnose a fault location?
Anyway, has anyone got any ideas?
I've tried everything.
Thanks!
What I've done:
Thanks!
