- 07-24-2012, 12:30 AM
Thread Author #1
!@$#! power and volume buttons!!!
Coming from a non-Samsung phone, the placement of the power button directly opposite the volume rocker is SERIOUSLY annoying. I keep unintentionally lowering the volume. I kept wondering why I wasn't hearing my phone!
I had to vent that.
Am I alone?? - 07-24-2012, 12:51 AM #2
- 07-24-2012, 01:17 AM #3
Re: !@$#! power and volume buttons!!!
I still hit the volume button when playing Angry Birds.
- 07-24-2012, 01:26 AM #4
I've gotten used to it. But I still don't like it...
Sent from my Blue 32 Verizon SGSIII using Tapatalk 2 - 07-24-2012, 04:31 AM #5
feelin ur pain man
power should be at top
- 07-24-2012, 04:36 AM #6
- 07-24-2012, 05:05 AM #7
- 07-24-2012, 05:28 AM #8
every android ive had had power on top. wonder if theres a way without root to disable power button?? then use ShakeOff app to turn screen off and home button to switch on...
- 07-24-2012, 06:35 AM #9
- 07-24-2012, 06:45 AM #10
- 07-24-2012, 08:29 AM #11
I've definitely hit the volume/power buttons at the same time...many times. I am learning to press above the volume button when using the power button though...I'm sure I will adapt.
- 07-24-2012, 08:32 AM #12
- 07-24-2012, 08:42 AM #13
- 07-24-2012, 08:46 AM #14
TOTALLY used to it!! I've been a Samsung ***** since the A900....you guys remember that phone?!!? BEST flip phone I ever had!!
- 07-24-2012, 09:09 AM #15
I can't stand the power button being on the top. Have you tried imagining to press the top for the power button on a galaxy note. Your hand would catch cramps. hell even on the GS3 is pushing it. Maybe its because I'm a lefty and I always unlock my phone with my left hand so I never ever had a problem with it, and it never even occurred to me how it would be a problem for anyone... until I realized that I'm a lefty.
edit: I just unconsciously unlocked my phone with my right hand, and i did not hit the volume button at all or was anywhere near it with my fingers. hmmmmmm Oh well.Last edited by s14tat; 07-24-2012 at 09:22 AM.
- 07-24-2012, 09:11 AM #16
I use a free app called "Volume Locker" that locks your volume settings. If you change your volume (or accidentaly hit the rocker), a prompt will ask you to save changes or revert to previous settings. You can set a timer for that prompt before it automatically reverts back to the old settings.
*Just noticed Predator04 mentioned the same app before me. Will back him up on this one. I've used it since my original droid and its helped with a few rogue volume changes.Last edited by wxjeremy; 07-25-2012 at 09:47 AM. Reason: crediting previous poster
- 07-24-2012, 09:16 AM #17
- 07-24-2012, 09:36 AM #18
- 07-24-2012, 09:39 AM #19
- 07-24-2012, 10:14 AM #20
- 07-24-2012, 12:21 PM #21
- 07-24-2012, 12:51 PM #22
- 07-24-2012, 01:17 PM #23
since I found out home wakes it up , I almost never use the power button anymore. I let it fall asleep on its own mostly, with 1min timeout
- 07-24-2012, 04:31 PM #24
- 07-24-2012, 06:27 PM #25
Still grab the top right of the phone thinking I'm gonna hit my power button... Getting used to it though and like most other people I inadvertently lower my volume while trying to hit power button more than I should.
Reply
