Witch Root Explorer did you download? I only found one at 4$..
We non-rooted users thank you.The problem is solved. No need to root, no need to factory wipe. You just need to clear the clipboard and reboot. Here's the easiest way:
1. Start the dialer app
2. Long-press in the dark area above the numeric keypad. Choose Clipboard, then Clear.
3. Reboot
This is a non-issue that is blown out of proportion because Samsung hasn't given clear instructions on how to get rid of bad-data that may be stuck in the clipboard. The steps above worked for me on my GS3.
You have 2 options;
1) Factory Restore your device
2) ROOT your device, install ROOT Explorer, navigate to / > data > clipboard, select ALL and delete all, than go into your Settings > Applications Manager > All, look for TestServices, than remove updates/clear data. Reboot and everything should be fine.
I opted for option 2 simply because restoring a device sucks and I wanted to root anyways because I missed AdFree, ROOT Explorer, and could not stand the WIFI Notification.
Thanks appreciated
Sent from my SCH-I535 using Android Central Forums
What did they tell you to do?I encountered the same problem with copy and paste. I called my service provider and they walked me through how to make it work and it works fine now.
Updated for those who don't have a dialer (tablet):
Samsung Galaxy S3/Note copy-paste bug resolved!
Don't listen to others - the solution is simple. No need to root, no need to factory wipe. You just need to clear the clipboard and reboot. Here's the easiest way:
1. Start the dialer app. If you don't have a dialer, see the note at the end of this post.
2. Long-press in the area above the numeric keypad where the numbers normally show. Choose Clipboard, then Clear.
3. Reboot
This is a non-issue that was blown out of proportion because Samsung hasn't given clear instructions on how to get rid of bad-data that is stuck in the clipboard. The above worked on my GS3 which recently developed this issue.
If you don't have a dialer: Open S-Memo and create a new text note. Long-press on the screen and you'll get a pop-up for Clipboard. Just click Clear.
Does this fix with root work with galaxy 4?
You ran into this problem with the s4?
