"auto adjust screen tone" (display settings)??
funkylogik
9,631
111
anyone have this checked/know what it does?
what does it detrament in favour of battery use?
ta :)
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
From the description I'd guess that it changes things like brightness, contrast and chroma of the screen (and perhaps backlight?) based on what's being displayed to attempt to lessen power usage. But that's purely guesswork.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
there is no backlight on s3 but the rest is probably right mate. think ill just keep it unchecked, i charge my phone like 2-3 timers a day anyway lol.
unemployed so battery life doesnt worry me much :)
Yes, it auto adjusts according to the light. I have it on when I'm working since I go between indoors and outdoors a lot so I don't need to fiddle with the brightness.
Sent from my ASUS Transformer Pad TF700T using Android Central Forums
so does it work independantly of the normal system "auto brightness" just for images or what mate?
My bad... I thought that was connected to the auto option in the pull down bar. Then for a second I thought it was why the stock browser is dimmer than other screens... But it's not that either. I've had it checked since I got the phone and playing around with it now I'm seeing no difference.
lol same, i cant find a difference mate.. if someone cleverer than us cant answer, il try and research it :)
r u cute btw Mandi?
sorry im bored lol
That's an odd question to ask on a tech forum.
Sent from my SGH-T999 using Android Central Forums
Odd indeed,but my s3 doesnt have that option above the "auto adjust screen tone" one. You have the international version no.?
Sent from my S3(:
Sent from my S3(:
nah its the "screen mode" option the north american models dont have for some reason. it only contains the options: natural, standard, dynamic, and movie. i prefer dynamic
sorry Mandi *alcohol* no offence intended.
i notice a pic has appeared though and u are :)
I have his option on the us version. Not sure how much it really helps the battery. Considering turning it off and seeing if it fixes my screen flicker issue
