Hi, i was wondering what phone i should choose.
What phone is better, easier to use, can someone tell me the differences?
Thanks
Thanks
^ ^ ^ Agree.All about preference. The Nexus is pure, vanilla android while Samsung adds their own touches to the s3. I personally prefer the s3 because it has expandable memory and a removable battery, the nexus doesn't. Also depends on what carrier you use. The s3 is LTE capable, depending on the carrier. The nexus is not.
Those items I listed might not be a big deal to some people though. Just do your research and im sure you'll be happy with either phone. Both are great devices.
Thanks
I would go for the S3. I was thinking of the N4, but with low memory, no battery swap, no sd card, and all the multiple issues it has, I decided to stick with Samsung.
Really, the Nexus 4 just has the build quality and fast software updates going for it, in addition to an awesome screen that trounces the S3. If you like the option of removable batteries and SD cards, then there really isn't a choice... but going with the Nexus 4 really takes care of the largest problems of Android (cheap plastic phones with fragmented OS updates), so you can feel superior to all of your iPhone toting friends if you are into that. Versus the Note II? That's a more reasonable comparison and one that I am having a difficult time making (as I own both but want to sell one of them).
Depends the s3 is a top of the line phone and doesn't receive updates very often, in fact its probably nearing the end of its life cycle.
The nexus 4 is mid range with no sd but it does run straight aosp, and gets updates straight from Google and it will probably continue to receive updates for the next 3-5 years.
Sent from my SPH-L710 using Tapatalk 2
Trounces the screen of the s3?....I disagree there is only 14 PPI difference and the colors are ten times better on the s3. The N4 screen is nice but I would not say it is any better just a bit different. I have them both side by side and watching videos and movies on the s3 is far superior. Also I'd like to point out that the battery life on the N4 is completely underwhelming and it doesn't even have 4G. Not to mention you can root your s3 and have updates pretty much whenever. I'm running 4.2 right now with zero issues.
Sent from my SCH-I535 using Android Central Forums
In the end, it comes down to personal preference, but I think most would agree that the IPS display of the N4 beats the pentile AMOLED display of the S3. The color reproduction of the S3 (if my Note 2 is anything to go by) is nice for viewing videos and games, but its pretty obvious the colors are blown out even in the standard display mode. It makes viewing any display that isn't an AMOLED seem disappointing in comparison. One thing that I do enjoy about TouchWiz is being able to select from a series of display choices to better suit what you want, however. And in fairness, the N4 screen can seem washed out in comparison to other displays (interestingly, the color calibration of the entire Nexus series appears to be the same across the board, judging from my time with the N7 and N10; compared to even the iPhone 5 and iPad 3/4's retina displays, they all seem pretty washed out). The S3 screen is not bad by any means, though. Agree to disagree?
Anyone else curious about what the OP decided? He never came back and commented in this thread.
