Re: Samsung Galaxy S3 wifi connection problems since firmware upgrade
I was having the same problem until a little while ago. After reading some tricks I ran into a fix myself. I've had the S3 since last September and on Sunday I had water damage. The phone was always connected to my Home Wi-Fi and I had no problems until I received this new S3 yesterday. I setup and updated the phone, but the S3 wouldn't connect, it simply said "Saved, Secured," referring to the wireless password.
I logged into my Router (standard Motorola SURFboard from TWC) using address
http://192.168.0.1/ A secondary address
http://192.168.100.1/ can also be used. Default username: admin --- Default password: motorola
For Linksys routers it's
http://192.168.1.1. Alternate address is 192.168.2.1. There are a lot of username/passwords for Linksys depending on various things so you may need to call your ISP. Found this on a website though:
Default usernames:
Linksys BEFW11S4, WRT54G: admin
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys Comcast routers: comcast
All other Linksys routers: [none]
Default passwords:
Linksys BEFW11S4: [none]
Linksys Comcast routers: 1234
All other Linksys routers: admin
Anyhow once you are logged into the router you need to find the page where it asks about
MAC addresses. For my Motorola SURFboard it was under the
Wireless tab in the
Access Control menu on the left. Just do a bit of browsing in the Wireless section and you should find it. Once you've found it you need to find the MAC address for your phone. Although it was all ready at the bottom of the router page with an ERROR I did not know the MAC address referred to my phone so I simply found it in my phone. For my S3 it was in
Settings >
Wi-Fi > then press the
Menu button which should bring up...well a menu. Click
Advanced and voila! Your MAC address is there. Enter it exactly into one of the many fields in your router settings and check or click Allow. For my SURFboard it was a drop down menu and I chose
Allow and then followed up by clicking
Apply. Return to your phone and connect it with the proper wireless password and you should be in.
If this at all seems confusing, calling your ISP and asking asking them how to add a MAC address to your router settings will suffice. Of course you will still need to find your MAC address on your phone.
