OK. new to this site so if this post relates to a similar issue could someone please re post it!
Re the charging issues.
I had an issue with my S3, not charging, I don't mean slow charging but NOT charging.... the charge icon not showing.
If I moved the charge plug around it would come on and start to charge which indicated a problem at the charging port..
I cleaned out the port (after removing the battery to prevent it shorting) with a needle.
This didn't solve the problem... I took the phone apart to see if there was a break in the connections from the charging port to the circuit board
Unfortunately as the connections are so minute you cant make them out without magnification. So I couldn't rectify it this way
The way I DID solve it was to cut a strip of PLASTIC approx 5mm wide and 30mm long
I used plastic from a milk bottle (empty one of course).
I used plastic because I initially tried cardboard but this kept leaving bits in the charge port.
The strip needs to go into the charge port UNDER the charge connection spade, (the opposite side to the contacts)
What this does is it makes a tighter fit for the charging plug. and it works every time
You can simply use the strip every time you charge the phone but you'd prob end up losing it and having to cut a new strip.
What I did was to take off the back and remove the battery, kink the plastic strip so it fits into the charge port and then bends around to fit inside the phone case behind the battery, relocate the battery which then holds the strip in place. replace the phone cover.
The plastic strip is now held securely.
The charge plug although a little tight to fit in, works 100%
OK this doesn't fix the problem, but if it is the charging port that has worn it is a cheap fix, your alternative is to have a new port fitted.
Another option which I am doing is changing the back cover to a wireless charging one, This has a coil fitted in place and the phone is simply placed on a charging dock and charges wirelessly, which obv removes the need for the charging port to be used.
Hope this works for some of you..
Let me know if it does..
