MHL 5 to 11 pin adapter charging slow
Nov 2, 2009
5
I have a Verizon GS III and I recently purchased a Pioneer Unit for my car. I bought and tried two different 5 to 11 pin adapters.One of them is from Samsung and both of them work with the app radio and show up on the display. The issue that I am having is that even though the phone is connected to a power supply, the battery drains while connected. If i remove the adapter from the equation then the app radio does not work but the phone charges just fine.
Does any one know if there is a problem charging through he adapters?
I also bought the connection kit from Pioneer that has the MHL to HDMI adapter in it. This is the reason why I need just the 5 to 11 pin adapter and not the MHL to HDMI adapter from Samsung.
GSDer
8,471
15
I'm totally out of my depth here - are you saying that your Pioneer stereo in your car has an HDMI input? And you're trying to use the MHL<>HDMI adapter (along with the 5-to-11-pin converter) to hook it up?
All I can tell you is that I've used the correct MHL<>HDMI adapter (the one that doesn't require the 5-to-11-pin converter) from Samsung to connect my phone to a TV (along with the required power input, of course) and haven't had a problem with the phone charging.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
Nov 2, 2009
5
Yes, the unit in my car has an HDMI input. The app radio allows the phone to displayed on the screen in the dash and there are a few apps that can be controlled from the radio's touchscreen. The problem is that every time I use the app radio, my phone battery drains faster then it can charge. Has anybody used the 5 to 11 pin adapter before to connect the phone to a T.V. and had similar results? I know that it not the power supply that I'm using because I have had the phone on plugged in without the adapter and it charged just fine. I connected the adapter while the battery was at 100% and it still drained while using the app radio feature.
smokedog87
