S3 Android 4.3 not sending SMS and audio media to car anymore
Pstongelitho
3
Hello,
Before my phone updated last week to OS 4.3, it would send the SMS to my Ford touch and my car (if I chose so would read it), was the same with Blue Tooth Audio media.
Since the update I had to manually couple phone to car, so I had to uncouple both device and delete each one and redo coupling and now they see each other whenever i start the car.
But SMS no longer are sent to car, nor do I get a notification from car saying that i have a new SMS, went into car settings for SMS's and car tells me that the phone is not allowing SMS to be sent.
Looked around the settings and I do not see anything that would prevent that, anyone know why ?
Also, under Blue Tooth preferences, on my Car profile, Audio for calls is checked, but phone will not check Audio for Media at all. Can anyone help ?
Thank you
drkrleitch
