I have a rooted jellybean S3 that will be two years old in August, and in the last 6 months I've had the charging port replaced, and I've replaced the battery. These problems I'm going to mention I've had with both batteries, so I don't think that's the issue unless they both completely died on me at the same time. For starters, it discharges at an accelerated rate.. and I don't mean if I'm sitting there using it, it will go down 1% less than every 60 seconds. I've somewhat fixed this by underclocking my phone down to the slowest possible (384mhz?) but of course now it runs poorly. I've left my phone charging over night, to wake up to see it 100%, unplugged it, went to the bathroom, went upstairs to talk to my wife, came back downstairs to see it at 45%, then left to go to the store and half way there it was at 25% (this was before slowing it down). Sometimes when it's plugged in, it still discharges.. using Battery Monitor Widget I've noticed that sometimes when it's plugged in it uses MORE power than when it's not. Turning it off to charge it has no real effect either. It doesn't feel super hot. I should also say that I did a factory reset the other day to remove any potential problems with something I've downloaded and it didn't change anything. Looking at my battery stats in settings I'm getting my screen at 46%, android os at 17%, android system at 14%, android media server at 8%, and everything else well below that. Any ideas? Thanks for any and all help
