Hey,
Wondering here what happens to features such as airview, air gesture, and the likes once you install a custom rom?
Will developers figure out ways to access them from stock android? And would developers enable them in other apps, as I assume that the main reason that other apps do not yet have airview/play support would be due to samsung not releasing an API.
Sorry if this is a bad question, but just wanted to double check that I'd still be able to use these features(at least at some point). While they could (easily) be considered gimmicks, I find a few of them useful(checking the time by waving your hand over the screen, or moving apps between home screens, are both pretty intuitive).
Thanks!
Thanks!
