Extra Battery + Battery Charger VS PowerBank. Which one will you prefer?
Omer San Gabriel
345
Extra Battery + Battery Charger = You can swap battery if the one you are using has run out
PowerBank = Portable charger
I'm not much of a power user but i'm planning to get one, but i'm not quite sure what to get. Can you tell me some Pros and Cons of the 2 items? And which one will you prefer?
PaulWog
47
The way I see it, they both have their pros and cons. I'm actually going to get both. Why? Well, why not. I'm not a power user either.
Issemann
733
4
Pros (+) and Cons (-)....
Extra Battery:
+ No wires necessary to recharge
+ smaller size to carry around
+ less expensive
- can only be used for your phone
- requires rebooting your phone
Battery Charger:
+ can power multiple devices
+ more power than a standard size battery
+ no rebooting necessary
- requires a wire to charge the device
- larger size for carrying
- more expensive
Omer San Gabriel
345
Extra Battery:
+ less expensive
Battery Charger:
- more expensive
Thanks sir! Much appropriated! But i wonder, which one will you get? :)
vferrari
331
http://q8allinone.com/wp-content/up...axy-S3-Battery-Charger-Stand-with-Battery.jpg
http://img.diytrade.com/cdimg/1351699/25381203/0/1334014379/POWER_BANK.jpg
Why both, of course!
I like the Anker 3000mAH external battery.
Sent from my GT-N8013 using Android Central Forums
Issemann
733
4
Well, I currently have the S3 with a spare battery. But I'm considering ditching Verizon to get the HTC One. If I do, then my only option would be the power charger.
If I stick with the S3 (or go with the S4, which is unlikely at this point), I'd go the spare battery route only because it's smaller to carry around.
dwhitman
253
10
I don't like depending on an extra internal battery, because using means I need to shutdown the phone, swap batteries, then reboot, and rebooting takes too long. YMMV, but for the few times I need extra power, I use what you're calling a PowerBank.
Really only use it when traveling, but works really well for me. I had a 12,000 mAhr pack, but it was too heavy. Sweet spot for me is about 4000-6000 mAhr - enough to recharge a couple times,without being too heavy to travel with.
Omer San Gabriel
345
What brand are you using? Or can you give me a link of it? :)
tohio
752
16
With a swappable, internal battery you put it in a go (takes me less than a minute on my S4). With a power pack you have to charge your phone with it attached. I wouldn't want to use the phone that monstrosity hanging off of it.
Raptor007
Trusted Member
Apr 18, 2010
4,906
58
I got a 5000mAh battery pack that has 1A and 2A charging ports a while back on an Amazon promo but I still plan on getting the spare battery and charger for quick swap and go especially when you don't have time to be tethered to a device for charging.
BTW, amazon.com has the Samsung 2600mAh battery+charger listed as coming on 5-26 and its up for pre-order.
mpdofficer514
81
Reboots on newer devices take less than a minute. So, would you rather swap out a fully charged fresh battery in 1 minute or have a rather large external battery hanging from your phone for an hour or more?
Sent From My Galaxy S4 Using Android Central App
rexxman
212
6
I have both but prefer an external battery. That one external battery can charge/power any device. An extra internal battery only works for that one device. When I carry the external battery I also bring a very long USB cable to make the tether easier.
Thanks for asking. Choose what works for you.
Blue 32gb Galaxy S3
PaulWog
47
I just ordered an Astro Slim2: [New] Anker? Astro Slim2 4500mAh Dual 5V 1A Output Ultra Slim External Battery with Hideaway Micro-USB for Android, USB Port for iPhones and other devices
Seems like a good choice. It comes with a built-in Micro-USB piece, and is relatively slim, so it'll be easy to pocket in a jacket.
I wanted to pick up their 2600mah battery, since it's only $13, but it only ships within the US and I'm Canadian :( I don't want to have to spend the extra cash on the Samsung-branded battery.
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
I prefer an extra battery, I wan never fond of carrying another device to charge my battery when all I need is to put a charged battery in my phone
trivor
371
29
28
I also have the Anker external battery - small, light, built in micro USB cable (tucks into the battery charger itself). Haven't even considered an extra battery - too much hassle.
Jaycemiskel
Trusted Member
Jul 28, 2011
2,769
4
I've had both and plugging up to a powerbank is a pain. It's bulkier than just having an extra battery plus you have to be tethered to it while it's charging. While it's true that it can power other devices, I usually only carry two other things, my tablet and my bluetooth headphones, neither of which usually runs out of juice so I have no need for it. This is coming from a person who has owned both. I pretty much never used the powerbank, but I swapped batteries all of the time. I eventually just gave the powerbank to my wife cause her battery isn't removable.
Sent from my GT-N5110 using Tapatalk HD
tohio
752
16
How could changing out a battery in less than a minute be more hassle than carrying around rather large (compared to a battery) battery charger and being tethered to it when you use it? Am I missing something?
ramhja11
