How to not allow apps to be installed on sd card
majdi suliman
50
yesterday, i bought a new 32gb s4, it was 32gb for a reason, i dont want my apps to be installed on the SD-CARD but some apps (rarely) install on sd
how to stop them doing this?? :eek:
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Apps should not be installing on the SD card. When you download they go directly to internal storage, and will only be moved if you do it manually. Either way, only very small amounts of the app are actually being moved (Less than a MB in most cases).
