A
AC Question
This is apparently a fairly widespread problem, but I'm having a lot of trouble finding any solves.
When I am trying to make a call over 4G or to receive a call the same way, there is no sound going out or coming in. When I am making the call, the little music of connection happens, but there is no ringing following.
I've gone through all of the other sovles that I could find so far. I actually did a reset of the phone (and had to put all of my stuff back again. bummer.) That worked for a week or so but here we are again. I've disabled all of the bloatware I could find. I do not have OK Google or any of the Google voice programs installed, I don't use Bluetooth, and Svoice is disabled. I turned off GoogleDrive. All of my ports are clean enough and functional. I're restarted and pulled/replaced the battery/SD/SIM many times. (This works on and off for a call or two.)
Calls DO work over WIFI and do NOT work in SafeMode.
My dread would be that its the SIM reader and has to take my phone out of my use for over a week. My annoyance would be that its a firmware thing that has no solution at all and has been ignored by Samsung.
Anyway.
Has anyone got any suggestions or thoughts? Appreciate it greatly.
Anyway.
